I own a small electronics device manufactured out of China produced by Game Pad Digital that has a 5.5" 1280x720 LCD touch screen and I have been looking into the viability of trying to find an aftermarket replacement for the screen. It is a 30 pin ribbon cable that uses a 32 pin connect to attach to the mother board with 2 inactive pins. I assume If I can identify what type of LCD the stock screen is and if I can find a similar enough aftermarket LCD then the pin outs would likely be uniform between the two LCDs or is that an incorrect assumption?
Assuming my thread isn't dead in the water with that one question I went ahead and posted the stock LCD screen with its identifying markings that I could find. Any help or guidance is much appreciated. Thanks in advance.
-Jonathan
-Jonathan
