recklessrog
- Joined May 23, 2013
- 985
Which country are you in?o
O.K. will check the fuse and let you know.
United KingdomWhich country are you in?
Yes R8 is the resistor that's blown in all 3 receivers, it's connected to the 'opto-couplers'.Is it R8 the Blue one, looks like 110 ohms 1%, does it feed one of the opto-couplers?
If worse comes to worst you can always post one to me as it will be so much easier with it on my bench. Just send me a personal message and i will give you my phone number if that helps at all .United Kingdom
The T2AL 250v which says T2 0A 250v on the fuse, seems o.k.
Yes, that's a possibility, lets see how we get on.If worse comes to worst you can always post one to me as it will be so much easier with it on my bench. Just send me a personal message and i will give you my phone number if that helps at all .
Preferably one that has not had anything done to it.
If it is cycling on and off then yes, but there could be numerous reasons for that. I will be popping into my old business this afternoon and will have a look for the circuit diagram which would help a lot so bear with me and I will get back asap.Yes, that's a possibility, lets see how we get on.
Because it's re-booting, could the power supply be going into 'protection mode'?
That would be good, circuit diagram.If it is cycling on and off then yes, but there could be numerous reasons for that. I will be popping into my old business this afternoon and will have a look for the circuit diagram which would help a lot so bear with me and I will get back asap.
I think we have something similar, I'm out with family today so will study it tomorrow and get back to youThat would be good, circuit diagram.
The R8 had blown and ballooned, scrapped the ballooned part off, the colours weren't clear, so had to guess. I'll check the opto coupler and report back.How did you determine the value of R8? Can you check that the opto coupler it is connected to is not short circuit pls. I'm looking at a circuit of a similar psu,
Hi dave, yes exactly that, I have a little process I would like him to follow step by step without jumping too far ahead so that we don't confuse him and lose track of where we are going. I have the schematic of a similar power supply and I think you are right. Hopefully we can get it sorted without him doing tests whilst connected to live mainsR8 (1.1K) could be used with R9 and IC2 the voltage regulator Tl431, to set the output voltage with the opto-coupler, if it's pulsing on/off could be going into overcurrent shutdown, or overvoltage, if you can trace the tracks of the opto-couplers to the resistor r8 and IC2 or take a closer picture of the trackside.
yes thanks, it is a little different physically, but that should not be a problem.I think this is what you wanted to see.
Yes but why and what else? the problem here is the info keeps changing, now we know it boots up with an error code. I am very unsure about the value of R8 as a similar psu has a 6.8k resistor here. We need to know the cause of the component failure. If echat takes up my offer, I will post the outcome on here..You cant test opto-couplers from input to output, you test the transistor C/E terminals for shorts or open circuit when voltage is applied to the led.
Looking at the pcb R8 is on the Led side and looks like the series resistor for the opto-coupler, so chances are the opto-coupler is duff too.
The information has not changed, I stated initially that it has an 'auto-reboot problem'. The error code is meaningless as that could be quite a lot of things. As for sending it off, it doesn't make sense. The additional receivers were picked up for a few pounds just for parts. The technology is old. I thought rather then buy another receiver I'd try to fix it. I've had it in the re-boot state for a couple of years, it's been sitting around.Yes but why and what else? the problem here is the info keeps changing, now we know it boots up with an error code. I am very unsure about the value of R8 as a similar psu has a 6.8k resistor here. We need to know the cause of the component failure. If echat takes up my offer, I will post the outcome on here..
