Troubleshooting AC Current Measurement Discrepancies Using Different CTs and Burden Resistors
Youssef ELBATTAH
Joined Oct 10, 2024
Hello everyone,
I'm working on measuring AC current using a current transformer (CT), the CT I’m using has a transformation ratio of 50:1, with a maximum current rating (Imax) of 50 A.
I’ve experimented with several burden resistors (4.7Ω, 1.2Ω, and 0.22Ω) and connected a logic analyzer to visualize the waveform and obtain the Vrms values.
Schematic:
Waveform (using a 4.7Ω burden resistor):
The waveform corresponds to an expected primary current of approximately 6.21 A. However, when calculating the primary current, I get:
Iprim = Isec *50 = (0.378/4.7) * 50 = 4 A
also tested another CT, the SCT-013, which has a 30A/1V ratio and comes with a built-in burden resistor. After repeating the same steps, I obtained this waveform:
So Iprim = Vrms * 30 = (212,806/1000) * 30 = 6,38
This result is much closer to the expected value.
Could anyone help me understand the discrepancy in measurements with the first CT? Any guidance would be greatly appreciated!
Best regards
panic mode
Joined Oct 10, 2011
5,240
the spec says the transformer is rated for 0.2VA and it looks like you are exceeding that by a large margin. sounds like core saturates and then output is of course less than projected.
since max output current is 1A, and maximum power is 0.2VA, then the maximum voltage output is just 0.2V (0.2VA/1A=0.2V). this is far less than your nearly 400mV. so burden resistor must not be more than 0.2 Ohm, I would probably go for 0.1 Ohm.
panic mode
Joined Oct 10, 2011
5,240
since this is a low power device, and initially burden resistor was way too large, it is conceivable that CT may be damaged (at 30A input that is 3VA which is 1200% overload). and if burden resistor was ever disconnected while sensed current was present, that is almost a certainty. which is why many products have the resistor built in - no accidental disconnects.
Youssef ELBATTAH
Joined Oct 10, 2024
Yes, I agree with you. I've also tried using a 0.22Ω burden resistor. When measuring the same device with an expected current of 6.21A, I obtained a similar result:
Iprim = Isec *50 = (0.0285/0.22) * 50 = 6.495 A
However, the issue arises when measuring very low currents. For example, when there’s no load (no power consumption), the waveform looks like this:
And the calculated primary current is:
Iprim = Isec *50 = (0.006/0.22) * 50 = 1.26 A
This is much higher than expected! I encounter the same issue with other low current measurements as well, where the readings are significantly higher than they should be.
panic mode
Joined Oct 10, 2011
5,240
also you are applying linear model to a nonlinear device.
even the "linear" region is not very linear.
so you probably want to use an amplifier to boost signal to desired level, as well as do some linearization in software.
38,790
For the best linearity, you can use a transconductance (current to voltage) converter, which will keep the burden voltage at essentially zero, but that would involve an op amp circuit with a 1A current buffer, and voltage supplies to power it.
