Troubleshooting 3 wire motor
Lawnmowerman
Joined May 11, 2022
53
Hello everyone, I’m hoping someone feels like helping me with my broken leaf blowers. I have two Ego 56v units that both stopped working in the same manner. I was humming along working and both my main and backup halted, one a few weeks ago and one this week. I tested the motor units with a multimeter set to ohms and they both read 0. I tested a few combinations of wires and nothing but when I spun the fan it read various numbers.
How would I test the control unit? They also have a 63v 680uf capacitor, it looks normal with no swelling. There’s no fuse that I can see. These are expensive and I would prefer to not drop the full price on two new ones. These blowers see heavy everyday use so I’m not terribly mad at the brand. There’s a weak link somewhere and I would like to have an extra component as at some point they are bound to break again. I’m married to Ego tools as I have many tools and many expensive batteries where switching brands would be cost prohibitive.
MaxHeadRoom
Joined Jul 18, 2013
30,735
I assume they are PM BLDC motors?
A test of the motor is to simply spin it and see if a voltage is generated on any pair.
You would need to preferably reverse-engineer the drive in order to do any fixing.
Or at least test the power semi-conductors.
Lawnmowerman
Joined May 11, 2022
53
I tested multiple combinations of the three motor wires and every one produced a voltage when spun.
Would you possibly give a little direction on this suggestion? The control box is sealed with a white rubber, possibly the inside is filled with it? No concern about the capacitor?
MaxHeadRoom
Joined Jul 18, 2013
30,735
If it is soft material, you may be able to chop/cut it out in order to go any further with testing, if epoxy, usually out of luck.
No doubt there is some large semi conductors mounted to the finned HS.
