Trouble understanding code
Killerbee65
Joined May 15, 2017
256
Code:
#include "Volume3.h"
#define speakerPin 9
void setup() {
  // put your setup code here, to run once:
  wolfWhistle();
  delay(1000);
  R2D2();
  delay(1000);
  pinMode(2, INPUT);
int switchOne = 0;
void loop() {
  // put your main code here, to run repeatedly:
switchOne = digitalRead(2);
if (switchOne == HIGH) {
     R2D2();
void gameboy(){
  vol.tone(speakerPin,1025,1023); // pa
  delay(70);
  uint16_t v = 1000;
  while(v > 0){
    vol.tone(speakerPin, 2090, v); // ting!
    delay(10);
    v-=10;
void wolfWhistle() {
  int f = 122; // starting frequency
  int v = 0;   // starting volume
  while (f < 4000) {  // slide up to 4000Hz
    vol.tone(speakerPin, f, v);
    v = 1023 * (f / 4000.00);
    f += 25;
    delay(1);
  vol.noTone();
  delay(100); // wait a moment
  while (f < 3000) { // slide up to 3000Hz
    f += 25;
    delay(2);
  while (f > 125) { // slide down to 125Hz
    f -= 25;
    delay(2);
  vol.noTone(); // end tone production
void R2D2() {
  int beeps[] = {1933, 2156, 1863, 1505, 1816, 1933, 1729, 2291};
  int buzzVols[] = {144, 180, 216, 252, 252, 252, 252, 216, 180, 144};
  int i = 9;
  while (i >= 0) {
    vol.tone(speakerPin, 1050, buzzVols[i]*4);
    delayMicroseconds(20*64);
    vol.tone(speakerPin, 1050, buzzVols[i] / 8*4);
    delayMicroseconds(40*64);
    i--;
  delay(35);
  i = 0;
  while (i < 8) {
    int v = 0;
    while (v < 250) { // 12.5 mS fade up time
      vol.tone(speakerPin, beeps[i], v*4);
      v += 10;
      delayMicroseconds(2*64);
    delay(20);
    v = 250;
    while (v > 0) { // 12.5 mS fade down time
      v -= 10;
      delayMicroseconds(5*64);
    vol.noTone();
    delay(25);
    i++;
  int f = 2466;
  while (f < 2825) {
    vol.tone(speakerPin, f, 1023);
    f += 3;
    delay(1);
  f = 2825;
  int v = 255;
  while (f > 2000) {
    vol.tone(speakerPin, f, v*4);
    f -= 6;
    v -= 1;
    delay(1);
  vol.noTone();
  delay(35);
  i = 10;
  while (i > 0) {
    i--;
  vol.noTone();
I added this into my code, not sure if it actually works or if the switch is just not working.
atferrari
Joined Jan 6, 2004
5,031
Next time learn to work with LTSpice. I spent maybe 4 months designing sound effects of various types. Even you can record and then listen your creations.
Pity all is gone with my defunct PC.
Killerbee65
Joined May 15, 2017
256
LTSpice? Never hear of it, hmm sounds really interesting. Thanks a lot I'll make sure to check it out!
