Possible but you don't know until it is tried. TS is probably doing this right now.But it was a DC amplifier, with a gain of 20, with a maximum offset of125mV
Some of the experiments we're running use the transducers at well under 1% of their capabilities. The full-scale outputs would be on the order of 5V. Hence, the 5mV output.On
https://www.pcb.com/products?m=482c05
footnote 1 says
"[1] With >= 1M ohm input impedance of readout device."
Not particularly clear what it means, but enough to sew the seeds of doubt in my mind.
It sort-of-implies that it should be driving a >1Meg input impedance, but maybe not.
If I had to design an interface without full knowledge of the "preamp". I'd choose a low-bias current op-amp.
I'm not even sure it is a preamp. What preamp would only have 5mV output?
On the other hand - it seems to have a 4mA output current to the sensor. Piezos don't need a bias current so what's that for? I've seen electrostatic transducers (Polaroid used to make them) which do need a bias current. Am I reading too much into this and seeing problems that don't exist?
We had most of the parts on hand to build this but I had to order the LT1212--they should arrive from Digikey by the weekend.
Ah! Thank you!The output of that comparator is a transistor open-collector (see below) so you need a pull-up resistor to get a voltage output.
Not necessarily.The dual version of the part Wally used is the LT1211. 1/2 for the input amplifier and 1/2 for the output comparator looks good to me, and you get a faster rising edge with no pull up resistor.
We're just using this to trigger a series of timers. I need to make 4 of the circuits that Crutschow suggested. As long as the outputs from each circuit have similar rise times to trigger the TTL inputs (within a few microseconds of each other), the slope of the rise won't affect the measurement we're trying to make.What is the timing resolution you are trying to resolve (?) ? My thought is that the LM393 is a relatively slow device, both in responding to a small change at the input and also in the speed of the output stage, particularly when turning off to make a positive-going edge. Do you have a feel for how fast the output edge has to be to capture the timing accuracy you need? An alternative to the LM393 output comparator is a fast opamp with near rail-to-rail performance. The dual version of the part Wally used is the LT1211. 1/2 for the input amplifier and 1/2 for the output comparator looks good to me, and you get a faster rising edge with no pull up resistor.
ak
