Triggering a thyristor with P channel mosfet
rjjenkins
Joined Apr 16, 2011
233
As I say, even when U1 is completely disconnected, the collector of Q1 stays low, regardless of the trigger input - unless it's disconnected from the T1 gate. I don't see how T1 is pulling it low.
rjjenkins
Joined Apr 16, 2011
233
Yes that's what I want. I want the thyristor to be on when the trigger is low. It's the same as what I was trying to do with the P mosfet.
So - the sequence is meant to be
trigger goes high - U1 starts to conduct, and charges C1. C1 won't discharge because thyristor is off.
trigger goes low - U1 stops conducting. Thyristor turns on and discharges C1
ericgibbs
Joined Jan 29, 2010
21,559
Hi rj,
If you post your complete circuit, showing component values and how you expect the circuit to operate, I will run the circuit in simulation.
What is the specification for the thermistor?
E
rjjenkins
Joined Apr 16, 2011
233
My feeling is that the thyristor is probably damaged because I didn't use a resistor to limit the base current. This might explain why the circuit worked for a while but no longer does. I will try with a new one.
