Hi, I'm new and I'm building some simple circuits for fun.
I'm looking for a component / a group of component that can function like a switch.
What I am thinking is something like a normal three pin switch, but instead of using mechanical methods to press the switch, you can use a small voltage to turn it on/off.
I've googled for it and transistor poped up. But I think its not the thing I'm looking for.
I'm looking for a switch that close when a voltage is applied. And the switch remain closed after the voltage is removed. And when a voltage is applied again, the switch becomes open until its triggered again.
Edit: should this be at circuits forum? I just notice that there is one after i post this but i couldnt delete this post and move it there
