Triggering multiple relays with a single momentary switch #2
computerlen
Joined Nov 26, 2011
11
Hi. I too have been trying to build a circuit using one touch switch that controls two relays. Pressing the normally open switch would latch one of the relays but then I need to press that switch again to undo the latch condition. Attached is a rough idea of what I keep coming up with. I truly would appreciate any help that you can give me. Len.P1090782.JPG
Rich2
Joined Mar 3, 2014
254
Hi. I too have been trying to build a circuit using one touch switch that controls two relays. Pressing the normally open switch would latch one of the relays but then I need to press that switch again to undo the latch condition. Attached is a rough idea of what I keep coming up with. I truly would appreciate any help that you can give me. Len.View attachment 237643
The only way to unlatch it is to remove the power briefly or put a switch in the lower cable.
Reloadron
Joined Jan 15, 2015
7,922
This thread is going on 4 years old. You would likely do better starting a new thread. That said if you are not adverse to using a chip a 4013 D flip flop would be my choice. Push button once to latch relay on and push again to unlatch relay. Also, as just pointed out your circuit as drawn will not latch and then unlatch unless you want to add a NC push button.
Ron
AnalogKid
Joined Aug 1, 2013
12,254
You are redirecting someone else's thread that is over years old. Please start a new thread with your question. If there is something in the old thread that you feel is relevant, provide a link to it in your post.
ak
Tonyr1084
Joined Sep 24, 2015
9,744
To have a single push button do what you want - the best way is to use a Double D type Flip Flop (DDFF). Amazon has many different types. Click HERE to see some.
Here's a circuit you may want to investigate: The NOT Q (Q with the bar over it) sets D opposite of whatever Q is. With each push of the button the D type FF (the box with the D, C, Q and NOT Q) will turn the transistor on or off. The transistor will control the relay. I've left out a ton of details just to show you the basic idea. The exact FF you choose will depend on the use, as well as will the transistor and the relay. Without details I can't give you any further support. The ONLY thing I can add that isn't in the drawing is a snubber diode across the relay coil. But you'll get there with the help of others from this website.
AnalogKid
Joined Aug 1, 2013
12,254
It is large and expensive, but all you need to go with it is one SPST switch and one diode (for a DC coil). Otherwise, a hex inverter can form three independent toggle circuits with only one relay each. AND, relay coil power does not go through any contacts, possibly saving relay $$$.
ak
38,741
Below is the LTspice simulation of a fleshed-out version of Tony's circuit.
The R1-C1 delay in the D input feedback is to ignore any switch-bounce (shown in the first yellow trace PB pulse).
The relay turns on and off (red trace coil current) for each push of the button (PWSW).
If you need the circuit to come up in a particular mode when power is applied, an RC power-on circuit can be connected to either the FF PRE or CLR input.
xox
Joined Sep 8, 2017
936
This simple circuit works with any normally-open push switch. It's composed of just five components. A quad opamp, three resistors, and a capacitor (to ensure a properly initialized state).
I've used an LM324 with it, but if you need a broader range of voltages you can simply use another opamp. Everything else is the same. It draws very little power and also tends to be more hardy than say the typical CMOS logic chip.
