Triangle wave oscillator with dual lm358 and single supply operation
Wai Khang Lim
Joined Oct 2, 2018
10
i am trying to build a triangle wave generator with the specifications as below :
  • The triangular wave needs to oscillate between V_max=7.2 V ,V_min=1.6 V
  • Duty cycle = 0.5±1%
  • Frequency,f_osc=8.5 kHz±5%
  • Supply voltage = 12V(single supply operation)
Does anybody have a formula or guide to build a triangle wave generator with two lm358 op amps?
the circuit i came up with does not give me the desired output
AnalogKid
Joined Aug 1, 2013
12,272
This is a homework thread on another forum.
The circuit you posted is a comparator with hysteresis driving an integrator. Do you understand how each of those circuits work? If not, then do some research into them and come back with specific questions.
Everything about this circuit can be determined with the LM358 datasheet, Ohm's Law, and the voltage equation for a capacitor.
ak
Audioguru again
Joined Oct 21, 2019
6,826
The circuit has an error causing it to not work. Some circuits in Google fixed the problem.
Hint: What input voltage polarity will make the output of opamp U2 go positive?
What needs to be added to do that?
Won't the crossover distortion produced by an LM358 cause kinks in the waveform?
