Hi
I have a problem with a tda1085c circuit.
The board has 2 terminal switch with a moving shaft.There are 3 positions. Position 0(motor stopped) posistion 1(right-handed rotation) and position 3(left-handed rotation).At the same time, moving with the shaft a potentiometer to adjust the speed.
if it has been pressed position 1 or 2 and after turn on the main power switch(230v), everything is ok with universal motor.
If i turn on the main power switch and press the terminal switch from position 0 to position 1 or 2 the motor starts with high speed and stabilizes in the right speed.The change of direction takes place with relays.
I have tried to change the potentiometer, but the problem is with the spikes from switches and the triac(bta26-700b)
Also i have tried to put electrolytic capacitors on switch contacts and gnd, but the problem remains.
Sorry about my english.
Could you help me?
Thank you
Could you help me?
Thank you
