Triac, M1/M2 always interchangeable, or sometimes or what?
Hamlet
Joined Jun 10, 2015
560
Is there a rule, I am with the understanding that M1/M2, or A1/A2 were interchangeable, no bothers worryn about polarity...?
Dodgydave
Joined Jun 22, 2012
11,395
Yes , but you have to change the gate signal too, as long as the Gate is the same polarity as MT2, .
There are 4 Triac Quadrants for triggering.
Hamlet
Joined Jun 10, 2015
560
I'm not using it to switch AC, but DC. As a bidirectional device, a triac should be able to swing both ways, yes?
bertus
Joined Apr 5, 2008
22,931
When a triac or thyristor is fired, it needs the voltage to go to almost zero to reset.
The triac or thyristor will "reset" below the holding current.
Bertus
Hamlet
Joined Jun 10, 2015
560
Bertus
That's fine, I'm discharging a capacitor bank. I'm new to both devices... can we switch an SCR with a diac?
Dodgydave
Joined Jun 22, 2012
11,395
Yes the diac will strike at approx 30V , then discharge the capacitor bank, and disconnect when the voltage is below the holding level.
