Treadmill with MC2100ELS-18w controller does not work
Ivanm911
Joined Apr 12, 2025
8
When turned on, the indication on the screen works, the track lifting works. but the main motor does not work. the diode on the board does not light up. 9 and 2 volts are coming from the transformer.
Sorry if I ask elementary questions, I'm a beginner in electronics just learning
Ivanm911
Joined Apr 12, 2025
8
Do you have a copy of the 'reverse engineered schematic?
Take a few readings of the required LV sources.
I replaced the voltage regulator. There are 5 volts at the output, and 5 volts are also supplied to the processor. but the diode does not light up.
Ivanm911
Joined Apr 12, 2025
8
When I accidentally shorted the second and fourth legs of the HD6 connector, the motor started and the diode lit up, but the main switch in the house was knocked out.Could this indicate that the microcontroller has no 0V?
Ivanm911
Joined Apr 12, 2025
8
What is "No 0v"?
Normally you should get a steady Lit LED when power up. and a flashing LED when the PWM signal is input (P4 of HD2).
The PWM signal into HD2 P4 is directed to, and isolated by the 4 pin OPto-isolator next to the HD2.
Oh, I'm sorry, I wrote wrong about 0V. Is it normal that the XRES pin is constantly 5V, or does it mean that the microcontroller is in reset mode and cannot start executing the program?
gaber2611
Joined Mar 14, 2013
327
What have you checked so far in the board?, main components such as transistors or Mosfets, are OK?, have you tested with multimeter?
Anything burned you see with your eyes?
Any corrosion or missing tracks?
Ivanm911
Joined Apr 12, 2025
8
I checked the main components. There is no visual damage either. I just can't understand why I have a constant 5 volts on the microcontroller. The datasheet says that there should be only a 5 volt pulse
gaber2611
Joined Mar 14, 2013
327
The microcontroller should have Vcc pin which have constant 5v
