Treadmill MC2100 HorsePower resistor ?
animal12
Joined Feb 20, 2018
48
Hope I'm in the right Forum spot for this question ? I harvested some treadmills & I unfortunately didn't label what came with what . I thought I remembered reading somewhere that there is a " Horsepower Resistor " on the MC2100's . I believe its the large rectangle one that is below the large cap in this pic . Does anyone here know of a list that says what resistor goes for which HP motor ?
thanks
animal
MaxHeadRoom
Joined Jul 18, 2013
30,881
No that is just a resistor to drop the DC for some of the logic circuitry.
There was only one model I believe that used that resistor.
animal12
Joined Feb 20, 2018
48
Thanks , so it's of to pair a TM motor with a different controller that it came with ? I've been looking on Ebay & Amazon & it doesn't seem that that question has come up .
thanks
animal12
MaxHeadRoom
Joined Jul 18, 2013
30,881
You need a compatible controller if mix and matching. There is a processor in the console and the motor board.
It cannot be ran directly off of 240vac, unless specifically designed for that voltage.
animal12
Joined Feb 20, 2018
48
Thanks , that's what I was thinking , I salvaged a commercial treadmill . It had a real nice motor , but that only the 2nd one I'd salvaged & wasn't thinking when I tore it apart to grab the top board too . The lower board which I saved is so far away from a MC2100 . I'll probably end up getting a KB or some other controller .
thanks
animal12
MaxHeadRoom
Joined Jul 18, 2013
30,881
What do you intend using the board for?
If using it for some other reason, you do not need the console controller, it can be ran with a signal into P4 of HD2.
animal12
Joined Feb 20, 2018
48
I guess I should have included more info in my last post . The Treadmill / board is made by Precor . There is no pinout labeling that I have seen on the board & a few calls to Precor got me nowhere with how to use the board . I had some pic's I took but there is too much glare on them , so I'll try to get some better pics in the next day or so . The board is not at my location .
thanks
animal12
MaxHeadRoom
Joined Jul 18, 2013
30,881
The picture of your board shows what appears to be the typical HD2 socket right at top left.
Pin 4 usually just requires a 20hz PWM signal into this pin to run the board, stand alone.
animal12
Joined Feb 20, 2018
48
That pic is when I was asking about a horsepower resistor on a MC2100 . The Precor board is the board that I can't find any info on . I will get some viewable pics of teh Precor board & will start a new thread .
thanks
animal
