Transmission line phase
jamus
Joined Feb 11, 2013
54
Simple question. In my electronics course, impedance was modeled as causing the current to lead or lag the voltage. Was this more of a "tool" or does it basically apply everywhere?
JoeJester
Joined Apr 26, 2005
4,390
I would say "everywhere" you have an impedance, you will have conditions a lead or lad condition.
Your lab associated with this should illustrate and reinforce the "ELI" and "ICE" conditions.
jamus
Joined Feb 11, 2013
54
What about in the case of a transmission line with a distributed inductance and shunt capacitance? The Vout would have the same characteristics as equivalent circuit elements?
33,222
For the question to make any sense, you need to be clear on the conditions you are talking about. In general, for the course you are almost certainly in, this means:
1) Sinusoidal steady state operation.
2) Linear systems.
In general the voltage across a device will lead the current through that device by an angle that equals the impedance angle of the device.
Of course, keep in mind that the impedance angle could be zero, making the voltage and current in phase.
33,222
If you are talking about transmission line theory in which you have distributed inductance and shunt capacitance (and possibly resistance and shunt conductance), then you need to take a step back and walk through the notion of "characteristic impedance" and what that means and how it is derived.
vk6zgo
Joined Jul 21, 2012
677
Reactance is that property which causes the current to lead or lag the voltage by 90°
Impedance is normally used for circuits which possess both Inductive & Capacitive Reactance (& in the real world,resistance).
Depending on the relative values of the two types of Reactance,current may lead voltage or vice versa,but,except where one Reactance =0Ω,it will not be by 90°.
Resonance
For every LC network,there is a frequency where Inductive & Capacitive Reactance are the same value.
At those frequencies,the voltage & current as applied to the input terminals of the network are in phase.
Hence the impedance at Resonance appears resistive.
