I currently have a circuit, that consists of an LED connected between the collectors of a PNP and NPN transistor (ZTX550, ZTX450). the supply is +9v, connected to a 250 Ohm resistor, in turn connected to the emitter of the pnp while the emitter or the NPN is connected to ground.
The resistor drops the 9v, to around 4v, the led uses 2v. Leaving 2v for each transistor. In saturation each one would use less than 1v. I know the resistor values I should be using to achieve saturation on either transistor, but I cannot seem to achieve saturation in BOTH transistors in this configuration. While this isn't an issue, I haven't been able to find a straight answer to if I can saturate both transistors in this configuration. Your opinions would be very helpful
, thanks in advance.
