transistor testing
denison
Joined Oct 13, 2018
334
Hi, I came across this on the internet for transistor testing.
"Connect the negative probe of the multimeter to the base output (usually it is a black probe), and the positive (red) first to the collector and then to the emitter. Obtaining a value in the range of~500 -1500 Ohm confirms correct operation of the transistor."
I tested 2 npn transistors and both gave infinite readings. They were both in the same circuit so I suppose they both could have failed.
Can anybody confirm that this test is correct?
Pyrex
Joined Feb 16, 2022
556
test transistors in diode mode on your meter. 0.4-0.8 V is OK.
Transistor is not a resistor with a defined resistance
Ian0
Joined Aug 7, 2020
13,281
@Pyrex is right - you must use the diode test function.
Also, to test an NPN transistor, base should be positive (red probe) and test between base and emitter, and between base and collector, with base positive in both cases.
For a PNP transistor, base should be negative.
A further test you need to do is to check for continuity between collector and emitter - if there is any, it fails.
You can test JFETs in a similar fashion - gate to drain and gate to source on diode test, but JFETs do have continuity between drain and source.
35,193
Furthermore, the polarity of your test leads depends on the test meter. Is it an analog meter or digital meter?
You need to do 6 tests.
b - c
b - e
c - e
c - b
e - b
e - c
BobTPH
Joined Jun 5, 2013
11,659
And that test, even if done correctly, tells you the transistor is bad if it fails, but does not mean it is good if it passes. It could still be bad in other ways (for instance, very low or no gain.)
35,193
I got a similar circuit to this one as a code practice oscillator from the ARRL Handbook.
My circuit used two 1.5V batteries and was also used as a battery check.
I used two transistor sockets and thus used this to quickly check PNP and NPN transistors.
BobTPH
Joined Jun 5, 2013
11,659
Yes, that would be a functional test.
I just use my $20 component tester, which will identify the transistor type, pinout and the gain.
schmitt trigger
Joined Jul 12, 2010
2,240
I am with BobTPH; I also own a low cost transistor tester that has proved invaluable over the 12 years I owned it.
But to your question, you would have to perform the 6 tests as MrChips outlined.
schmitt trigger
Joined Jul 12, 2010
2,240
While we are on the subject of transistor testers, I also recommend -for more advanced users- obtaining some sort of SMT adapter, at least for the small yet very common package, the SOT23IMG_3916.jpeg
dl324
Joined Mar 30, 2015
18,472
Are you testing the transistors in-circuit?
A junction test will only give a DORA (Dead OR Alive) indication. A curve tracer is a better tool for characterizing transistors.
When I was a technician, I used a continuity checker as a quick way to identify dead transistors in-circuit. Diodes in parallel with junctions can give misleading results...
