Testing transistor from middle pin (base), to another pin gets Open Loop
abdulbadii
Joined Aug 30, 2017
90
If we tests transistor from middle pin, assuming it base, to another pin gets Open Loop (OL), would it indicate a defect/broken transistor if test it to the next pin gets some sound voltages (more or less 1 V)?
ericgibbs
Joined Jan 29, 2010
21,584
hi,
OK,
If you get an o/c reading between the Base and either the Collector or Emitter it could mean the transistor is faulty,
Which type of transistor are you testing.?
E
KeithWalker
Joined Jul 10, 2017
3,619
The base to emitter junction and base to collector junction in a BJT transistor both act like diodes, When you use a diode tester, check them both in both directions by intrchanging the test leads. In one direct it will read around 0.7V. In the other it will real OL on a good transistor
