Transistor LED dimmer
BobTPH
Joined Jun 5, 2013
11,515
Again for the third time speaking only about the dissipation on the transistor.
That is not the definition of efficiency. I never claimed that they both dissipated the same power in the transistor.
The PWM circuit is supplying twice the current half time and thus supplying the same light. The power drawn from the battery is identical, so the same output at the same power means the same efficiency.
As is always the case, that is not the whole story. Typical LEDs are less efficient at higher current. So the PWM method, in a real circuit is actually likely less efficient.
38,507
Nobody said you did and if a transistor is consuming less power and more going to the load then it's operating more efficiently!
But the load includes the series resistor, so the power dissipation is just transferred from the transistor to the resistor, thus no significant improvement in overall efficiency.
(Note, that if you increase the peak current for PWM operation, the resistor dissipation increases with the square of the current.)
BobTPH
Joined Jun 5, 2013
11,515
How much power are the resistors dissipating in both circuits? Do The Math. You would then stop making a fool of yourself.
sghioto
Joined Dec 31, 2017
8,634
Yeah it's the same. But what is it that you don't get? I've been talking about just the transistor or are you just being silly?
BobTPH
Joined Jun 5, 2013
11,515
What I don’t get is that a knowledgeable person like you could make and defend this statement:
I believe the term efficiency in this application is referring to the dissipation of the transistor in the linear mode vs PWM mode
No, efficiency is
Useful power / total power.
By your definition, the efficiency of a circuit with only a resistor and LED would be 100% since there is no power dissipated in a transistor.
Edited to add: Electrical Efficiency
william.in.rs
Joined Jul 14, 2012
22
Somebody should start a new thread "Linear mode vs PWM mode LED dimmer" and continue discussion there.
Can anybody answer my questions:
1. What should be values of resistors R16 and R18?
2. Are Q3 and Q4 really PNP transistors?
3. Is 200 mW minimum dissipation for Q3?
Externet
Joined Nov 29, 2005
2,635
Can anyone explain why these circuits posted have the load on emitter instead of the collector ? And what would differ if the load is instead, on the collector ?
34,812
You are correct. I showed my circuit working with 2 LEDs. As you add more LEDs you have to increase the base emitter current.
34,812
Load on the collector (common emitter configuration) provides voltage gain.
Load on the emitter (common collector configuration) provides current gain. We want to control the output current to the LEDs and don't care about voltage gain.
It also has built-in negative feedback. If the current tries to increase, the base drive is decreased thus keeping the LED current constant.
Audioguru again
Joined Oct 21, 2019
6,826
With your pot set at max output voltage, the unloaded voltage divider produces only 5V/3= 1.67V and the LEDs get less than 1V each. Whte leds at less than 1V produce no light.
