Transistor circuit analysis problem
taarkikguy
Joined Dec 1, 2019
Circuit diagram- here
Okay so we need to calculate V which is Vb1e1 I guess. If we can get Ic1 then Vb1e1=R5*Ic1 if I'm correct.
We have B=100 so Ic1=B*Ib1 ie 100Ib1. If we are to apply KVL, how do we go about it?
What is the overall voltage in all the loops?
Also, is it correct to use voltage division rule and say that
Va=12*(10k/(10k+20k+10k))= 3V
Vb=12*(20k/40k)= 6V
and, Vc=12*(10k/40k)= 3V
How do I proceed with the voltage division rule method or is it even the correct method. If not then how to solve using the KVL method?
If someone can help it would be great. Thanks
Jony130
Joined Feb 17, 2009
5,601
What you got is an approximation solution (not exact). Your calculations do not include the base current effect.
Try to apply the Thevenin's theorem to R1 and R2 and write some KVL after you simplified the circuit.
WBahn
Joined Mar 31, 2012
33,282
If Va and Vb are the voltages at the points marked A and B in the diagram, how can they be anything other than 12 V.
If they aren't those voltages, which voltages are they?
RBR1317
Joined Nov 13, 2010
715
KVL would imply using mesh analysis. But I don't like mesh; never touch the stuff. A good way to start is redraw the circuit with the appropriate transistor model. Here is the equivalent circuit with each transistor replaced by a super-node & a current-controlled current source. Also a screenshot of the Maple math application performing the nodal analysis. (Units: V-volt, I-mA, R-KΩ) So, is the correct answer Vout=6.4835?
Zeeus
Joined Apr 17, 2019
616
Hi :) Please look at last post here : https://forum.allaboutcircuits.com/threads/transistor-circuit.165390/page-2#post-1456792
Calculating Dc
WBahn
Joined Mar 31, 2012
33,282
Please don't just give out solutions -- at least not unless you are going to go take their exams for them and do all of their work for them after they graduate, too.
RBR1317
Joined Nov 13, 2010
715
I don't do homework; however, after some period of time it ceases to be homework. Is 7 days not enough time?
WBahn
Joined Mar 31, 2012
33,282
Fair point. I'd recommend at least two weeks, since that is a very common amount of time between when assignments are released and the due date.
