Hello everybody!
I am currently looking to replace some components in my Customers Emerson 2612MKII. Everything was going along swimmingly except for a transient voltage suppressor - p/n: SM91
The only place I was able to locate this part was on UT source however it was the wrong size - the SM91 I am replacing is about 5mm by 3mm, the one I received was about 3 times the size. I am assuming the easiest solution to my problem would be to cross it - alas TVS's are not my specialty and everything I've found is just a little off. Can anybody one here that knows more about TVS's perhaps recommend a solution?
Thank you!!
Andy
Thank you!!
Andy
