MaxHeadRoom
- Joined Jul 18, 2013
- 30,810
There is a significant difference in efficiency between EI core and the Toroidal transformer. the losses are much less in Toroidal due to the magnetic field retained in the core, also the turns ratio is far less in a toroidal version.Can you tell what are the other factors?
All I know adding more layers increases resistance by some number (the diameter of more outer turns increases), so R losses increases.
The next is decreased coupling factor since middle distance between primary and secondary increases.
