I am trying to use transformers in linear switching, using 2 FET's at the primary side of a ceter tapped transformer. The secondary windings are attached to a multiplier so that I can get around 700V.
The problem is that the transformers either saturate much earlier, or if the dont, they never provide the required current drive at the output, which limits the output power.
I have tried using PICO 32688 and PICO 32694, both of which have rated output powers at 3W.
The maximum Im getting is under 1W. Any suggestions on increasing the current drive?
