Transformer Secondary Windings Identification
hi Scott.
Do you know which type of equipment the transformer was originally powering.??
Eric
BTW: did a web search for that Toshiba code, inconclusive.
I have a theory that it might have been medical equipment because it *appears* to have much better than usual isolation barrier between what is assumed to be the primary and the secondary.
If I am right about the way this transformer is wound, the primary is inner most and fully enclosed within a section of the bobbin and the wires to the terminations are also fully enclosed within the same section right up to the pins which are then shrouded by an extension of the enclosure around the primary winding.
A normal transformer with a low voltage secondary needs an isolation barrier in the order of 6.4mm creepage and clearance between primary and secondary. For medical equipment where a patient may end up physically connected to the equipment, directly or indirectly, the barrier is more like 10mm creepage and clearance. In a small-ish transformer this can be a problem so the fall back position is a barrier formed by solid insulation which only needs be 1mm or so thick but must be guaranteed to have no voids or otherwise be less than the required thickness anywhere and everywhere it provides the isolation barrier. I have seen bobbins that do this by being in two halves with one sliding into the other and the core then going around both as if they were one single item (ie in the normal way). Vacuum impregnate with a suitable varnish / polyurethane and hey presto, medical grade isolation barrier fully formed.
I am thinking that the yellow band is either an electrostatic shield or just insulating padding to stop the windings buzzing. It can't be a flux band because it is inside the winding window and the heavy metal surround would probably answer for that anyway. If the outer metal housing could be tested for hardness it might be found to be mhu metal in which case it is definitely a magnetic shield and therefore the equipment was probably sensitive to stray magnetic fields, as one might expect medical equipment to be.
Just a thought with a long rambling explanation. Could all be bollocks ;) or maybe right. Who knows.
What it looks like to me is that it was, or was intended for, was a power supply for an older VCR power supply. Those usually had several voltages, one for the display, one for the motors, and one for the electronics in general, and then a higher voltage supply for the electronic tuning for the TV receiving tuner. It may also be intended for an all-in-one radio-cassette player box, although they don't often have a PCB mounted transformer..
The pins with two smaller wires may be taps on a higher voltage winding, sometimes that is done to save money, instead of having separate windings. So I am thinking that the mouse-hand drawing may be a close representation of how it really is.
So maybe the 100V for vacuum fluorescent display? But centre tapped and for such a low current? The CT 50V could be for an audio amp....
28,331
VF displays in VCR s don't seem to use much current, but they do have a low voltage heater filament. The center-tapped 50 volts would provide about 30+ volts for an audio amplifier of somewhat higher power. Of course, it could also be for some totally different application as well, those are the ones that I am familiar with and can offer an opinion about.
smachado
Joined Feb 4, 2018
10
Hello All/Eric,
This came from a Sanyo DCX690 receiver. Unfortunately, I also struck out w finding info (schematic) for this unit.
More thanks for the additional thoughts...
Scott
