Not to change the subject, but let's say if we had one turn through secondary, the secondary is already shorted...what if uninsulated wire was used and half the secondary loop was shorted with each other. The resistance will be half? Will all the currents double?More turns = more voltage, as long as the load resistance is the same, and zero load current is a good thing.
Trying to calculate the sum of all impedances is a PIB. (Pain In Behind)
Measuring is so much easier!
Do not short a turn for more than a few seconds or you risk overheating the transformer.
