Transformer ratio
Ian0
Joined Aug 7, 2020
13,278
Yes, but its current rating remains the same, even though the voltage has reduced, so its power rating has also reduced.
Tonyr1084
Joined Sep 24, 2015
9,744
Removing seco dary turns, what does that mean
It means if the secondary number of turns is X then removing half of the turns will result in half X. In other words, for example, if the secondary consists of 500 turns, removing 250 turns will drop the output approximately half. I'm no transformer expert but I'm comfortable stating removing half the turns results in half the output voltage. But the wire gauge is not going to support the same wattage as it did before. Certainly half the wattage, possibly as much as 1/4th the wattage. Like I said, I'm not the transformer expert.
28,286
Given that a transformer is built with a specific turns ratio which provides a specific voltage ratio THAT RATIO DOES NOT CHANGE WITH A DIFFERENT INPUT VOLTAGE. So supplying half the input voltage will result in half the output voltage. Post #4 is correct, because the CURRENT rating is set by the wire size.
The transformer EFFICIENCY will be a bit better at 60Hz, than at 50 Hz.
And there is no reason to consider modifying the transformer.
MaxHeadRoom
Joined Jul 18, 2013
30,810
I have modified too many to remember in my time, in many cases it is fairly simple, even winding on a complete new winding.
Toroid's are the easiest, They require ~ 2turns/volt, compared to EI which are often up to 5 turns/volt.
28,286
There are a lot of people who are not well experienced in modifying transformers, and certainly doing it successfully and accurately takes both skill and experience. So while Max has been modifying transformers daily for over 50 years, quite a few folks have never done it at all.
Besides all of that, In another current thread is shown a classic circuit to get both 12 and 24 volts DC from a single center tapped transformer winding. Which is not what the TS asked for but it really is a neat trick.
MaxHeadRoom
Joined Jul 18, 2013
30,810
Everyone has to start sometime! :(
Another ploy to double the capacity when using half of a CT winding is to open the centre connection, move one of the CT's over, and make them capable of parallel operation.
