I am tasked to calculate the conversion ratio; I presume it is the duty cycle of a Buck-Boost. The transformer model of the original circuit is shown in my work.
The turns ratios are correct: 1
and 1:1/(1-D). The effective resistance is also correct (RL+Ron*D), and the effective voltage is also correct (Vd*(1-D)).
Pushing the voltages and resistances through the transformer I arrive a the last circuit so it becomes a simple voltage divider.
I do believe my voltage divider equation that I boxed is correct. If RL and Ron were to be 0 ohms, we are left with 1/1 which reduces to 1. If the diode effective voltage was 0 then we are left with the ideal buck-boost equation:
(Vg*D)/(1-D) = V, where Vg is input and V is output.
The problem is, how in the bloody hell can this be manipulated to achieve V/Vg?
