Transformer output
PaPiャSly
Joined Dec 25, 2022
47
Hi, so im trying to use this transformer as powersupply and it already has a rectifier and capacitor to filter the output, my concerns are the following :
-Votlage output from the rectifier is 20v but it charges the capacitor upto 27v
-also scared to use it on my amplifier cuase the current isn't regulated
Im just a newbie so I'm trying to gather more information for my project
Alec_t
Joined Sep 17, 2013
15,167
Welcome to AAC.
Voltage output from the rectifier is 20v but it charges the capacitor up to 27v
Are you sure the 20V is from the rectifier and not the transformer? Something could be wrong if 20V on the rectifier gives 27V on the capacitor.
If the transformer has a 20V rating, this is RMS (root mean square), so the peak voltage for a sine wave will be 20 x the square root of 2, = 20 x 1.414 = 28.3V. If the rectifier is a bridge, there will be a voltage drop across two diodes, so the capacitor will charge to 28.3V - 2 x 0.65V = 27V.
Is your amplifier rated to handle a 27V supply? If so, it will draw whatever current it needs.
MrAl
Joined Jun 17, 2014
13,889
Regular transformers with rectifiers and capacitors will charge the output up to 1.4 times the nominal AC value in Volts RMS. So if your AC rms voltage is 10 volts it will charge up to 14 volts DC and if AC rms is 20 volts then it will charge up to 28 volts DC, and that is before you apply a load.
To get 20v output constant you need a voltage regulator on the output.
dl324
Joined Mar 30, 2015
18,521
Welcome to AAC!
The peak output voltage at the filter cap will be 20V * 1.414 minus the voltage drop for whatever rectifier you're using; 1 diode drop for half wave, 2 for a bridge rectifier. The output voltage will be higher if the transformer isn't loaded.
The amplifier will only take what it needs after you regulate the voltage to what it needs. What is the amp's current requirement and what is the transformer secondary rated for?
PaPiャSly
Joined Dec 25, 2022
47
Welcome to AAC.
It's only py rated to handle 24v 5a so im also trying to find a way to regulate the voltage
PaPiャSly
Joined Dec 25, 2022
47
PaPiャSly
Joined Dec 25, 2022
47
Welcome to AAC.
It is only rated for 12-24v 5a but i wanna regulate the transformer output voltage to 20v
PaPiャSly
Joined Dec 25, 2022
47
Welcome to AAC!
It is only rated for 12-24v 5a but i wanna regulate the transformer output voltage to 20v replied on my thread with some pics for the transformer specs
WBahn
Joined Mar 31, 2012
33,342
Is the transformer rated to deliver the 5 A that your amplifier might need?
If you want to regulate it with a 78xx regulator IC, then you are going to need to include circuitry to provide current bypassing since those regulators don't like to put out more than 1 A of current (if properly heat-sinked).
PaPiャSly
Joined Dec 25, 2022
47
I don't really have way to find what mu transformer current rating is
MrAl
Joined Jun 17, 2014
13,889
Do you need 20v at 5 amps? That is significant power you may have to use a switching regulator. A linear regulator may eat up too much power and get hot.
You also need significant capacitor filtering to keep the unregulated voltage dips above about 22 volts.
