Dimmer switch.Sticking with AC, as a power source for a plastic bender, what device could be used to vary the output voltage/amperage? A dimmer switch? A motor speed control?
Depends on what voltage it is. dimmer or variac, ..Sticking with AC, as a power source for a plastic bender, what device could be used to vary the output voltage/amperage? A dimmer switch? A motor speed control?
