Just to make sure, can you post how the grounds are hooked up? Just a block diagram showing every time ground leaves a major component. For example: Start with frame ground, 5 volt ground, your circuit ground, your sensor ground and the ground for what your circuit drives.
We wouldn't want to just treat the symptoms and have the beer cooler down the hall create the same problem.
Is the sensor shielded wire?
