Track Width Calculation for 230VAC @ 1A Current - Help Needed
mishra87
Joined Jan 17, 2016
984
Hi All,
How do i calculate PCB track width for AC signal as per below specification :
Input - 230+-10%, 50/60Hz
Current - 880mA
Current - 100mA
ericgibbs
Joined Jan 29, 2010
17,136
hi,
OK, so what track width have you decided to use.? note the Internal and External use, track requirements.
E
BTW: Also consider the minimum Line/Neutral Earth tracks separation from each other and any other tracks [ ps and humidity levels]
mishra87
Joined Jan 17, 2016
984
hi,
E
Thanks !!!
Track width = 2mm.
Minimum creepage at connector is 2.1mm b/w Line and Neutral. (As per IEC60335-1)
Minimum creepage at anywhere in board 2.5mm b/w Line and Neutral.
Regards
ericgibbs
Joined Jan 29, 2010
17,136
hi,
Looks OK, I have one query, the pads marked with a white line, are they Plated thru holes, if yes, what clearance do you have from what appears to be a Green underlying track.?
E
mishra87
Joined Jan 17, 2016
984
hi,
E
Thanks,
Its PTH pads and it is in botton layer.
Minimum crerance seen is 3.2mm.
ericgibbs
Joined Jan 29, 2010
17,136
hi,
Page 1 of this PDF explains the difference, eg: surface versus multi layer internal
E
Clip:
A PCB consists of 1 or more layers of insulating plastic with copper wires on top, known as traces which connect the various components. ... The external layers are the top and bottom of the PCB, and the internal layers are placed in-between these.
