Hi every one,
I design a PCB which power trace should be cable to carry 16A. I found two online calculators claims that their calculations based on IPC-2221 standard.
However inserting the same parameters in both calculators there is significant deviation between the results
Calculator 1
https://www.4pcb.com/trace-width-calculator.html
Calculator 2
https://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-pcb-trace-width
I attach the screenshots from the results
Thanks in advance
Calculator 1
Calculator 2
Thanks in advance
