TPS Voltage regulator not working
micropad
Joined Dec 24, 2011
109
I am using this TPS voltage regulator, which originally came with a 12V output, but I want to change it to 5V. I connected the 5V pad, but the output voltage is still 12V. If anyone has experience with this, please advise on how to get a 5V output.
Adj pad also connected
28,371
How much current were you drawing from the output that is supposed to be five volts??I see separate "ground" terminals for input and output, how was your load connected??
Did you receive any application or specification with this module??
