I want to us this touch switch circuit in a project. It works fine, but I need to modify it. Currently, when power is removed and then reapplied, the circuit returns to the state it was in when power was removed. For example, I can turn the LED on and off using the two contact points, but if the LED is on and I remove power, the LED will be on when I reconnect the power. I need the LED (and relay) to always have no power to it (them) whenever power to the circuit is restored. What change(s) do I need to make?
