torque required
barrygold
Joined Dec 19, 2012
1
Hi, I am new to this!
I am struggling to answer the following:
what size ( torque etc. ) 6 volt dc. planetary gear motor would I need to lift
a 3kg. load vertically.
I plan to couple the gear motor directly to a 12mm dia. steel acme lead screw
with a 3mm pitch.
The load I will attach to a brass lead screw nut.
A stainless steel guide will stop the nut rotating and so give it vertical travel.
Any better guesses out there than mine ?
Thanks all.
33,021
Could you provide a rough sketch? I have two very different mental pictures of your arrangement depending on how I interpret your description.
BillO
Joined Nov 24, 2008
1,001
Also, what is the gear ratio of the planetary gear motor, or do you just need the torque after the planetary gear?
Do you need a theoretical response assuming loss-less gears and screws or do (quite likely relatively high) frictional losses have to be taken into account?
