toroid and binocular cores
mdidomenico
Joined Mar 3, 2019
18
are toroid and binocular cores inter changable? i'm totally out of my depth here so this might come off as stupid. looking at toroids.info a t50-3 at 200khz and 5000uh requires 534 turns through the toroid whereas a bn-73-202 binocular core only requires 20. clearly i'd much rather wind 20 turns then 534, but i don't know whether it's apples to apples.
SLK001
Joined Nov 29, 2011
1,548
I would bet that these two devices have drastically different permeabilities. Get a toroid with the same permeability as the other and your turns should be near 20.
mdidomenico
Joined Mar 3, 2019
18
interesting. the binocular core has an al=12000 whereas the t50-3 is 17.5. looking at digikey i was able to find this toroid
https://www.digikey.com/product-detail/en/ferroxcube/TX22-14-6.4-3E65/1779-1529-ND/8021243
which is lower then the 12000 of the binocular core, but persumably that just means i may need to wind ie 30 turns instead of 20. if true i'd probably have to pick up an LCR meter to make sure. otherwise i haven't been readily able to find standard toroid shapes with an Al near 12000
they also have these split things
https://www.digikey.com/product-detail/en/epcos-tdk/B65807J0000Y066/B65807J0000Y066-ND/3914132
which i presume require a bobbin and clip/mount, but i've never used them before, so they're a little scary. and at $2.50 a shot could be an "expensive" experiment
