I have been trying to use a TMB12A03 buzzer in a circuit. It doesn't sound when I think it should. I finally constructed a simple test circuit to try to understand what's going on. When I put a 9V battery across the terminals of the buzzer, it sounds. When I put the 9V battery across the buzzer in series with a 1K resistor, it doesn't sound. (see attached sketch).
What am I missing? The buzzer has the positive terminal marked, and I was careful to make sure to observe the polarity when connecting it to the battery. I measured the resistance across the terminals of the buzzer, and it is in the 1M range--so I wouldn't think adding a 1K resistor in series would make much difference. I also tried several different buzzers from the same batch with the same result, so I know it isn't a failed buzzer.
I downloaded the data sheet but didn't see anything that would indicate why it isn't working. (see attached file).
I'd appreciate any insight or suggestions.
