TLVH431 biasing resistance and output voltage calculation ?
mishra87
Joined Jan 17, 2016
1,063
Hi All,
I want to give very precise voltage reference to MCU(STM32F4) Vref+ pin for my measurement.
So could any body explain calculation for me.
Vin = 5V
Vout = 3.3V
R_supply : ?
R_upper : ?
R_lower : ?
Vout : ?
Regards
38,946
I don't understand the IREF = 1mA in the table, as the data sheet only lists a maximum of 0.5μA.
But you obviously didn't use that value in your table calculations, since those values for R1 and R2 seem correct for the low (or zero) value of IREF.
How "very precise" do you need the voltage?
mishra87
Joined Jan 17, 2016
1,063
0 5% accuracy . I want .
I gave someheadroon 0.5uA to 1mA.
I took some headroom for these calculation.
Dodgydave
Joined Jun 22, 2012
11,395
Hi All,
Vin = 5V
Vout = 3.3V
R_supply : ?
R_upper : ?
R_lower : ?
Vout : ?
Regards
Any resistors with a ratio of 0.32 for R1/R2 = 3.3V out
