TLTiny85 Question
PastorJeff
Joined Jun 13, 2020
8
What is the preferred method to have a variable output voltage from these types of chips?
I'd like to be able to vary the output from as close to 0 to the chips expected voltage out at
5vdc
Papabravo
Joined Feb 24, 2006
21,225
5vdc
Don't know about preferred, but possible
  1. PWM to place a charge on a capacitor. Use the on board comparator or the 10-bit to monitor the capacitor voltage.
  2. Serial DAC with SPI or I2C interface.
PastorJeff
Joined Jun 13, 2020
8
I probably should have said what the output is. The chip is putting out a set of times pulses. Variable/ min
I just don't want the full 5 volts
Papabravo
Joined Feb 24, 2006
21,225
If you don't want the full 5 volts you don't have to crank the duty cycle of the PWM up to 100%. Don't you know that you cannot change the value of the voltage across a capacitor instantaneously?
Papabravo
Joined Feb 24, 2006
21,225
What makes you think all six aren't?
The TS has not said what else he wan'ts to do, and that is why we do not know what is or is not available. This is not uncommon in forum posts by newer users. It takes a while before they learn to include relevant information so the responses are as helpful as possible.
DickCappels
Joined Aug 21, 2008
10,179
Are you asking about the ATTINY85?
The 8 bit PWM outputs are pins 5 and 6. If you want to use a different pin you can bit-bang the PWM.
See section 13.8 of the datasheet.
