TLC555 2 Led Flasher issue
ShockBoy
Joined Oct 27, 2009
186
Hi All. This is my First post here, I Love this site. Very full of great information. Anyway, I am using a tlc555 ic to flash 2 LED's 5mm. Here is the issue. One led works great, the other flashes, though does not go off.
When I remove one LED the other (that was continuously on and kinda blinking) blinks normally. To me this seems like..well I don't know.. Thanks All for any info.
SgtWookie
Joined Jul 17, 2007
22,230
It would help a great deal to post a schematic (.png format preferred) of the exact circuit you're using.
The TLC555 is a CMOS 555 timer. It can sink about 10 times as much current as it can source. This may be why you are noticing such a difference in LED intensity.
SgtWookie
Joined Jul 17, 2007
22,230
You can!
Click the "Go Advanced" button below the reply text box, then click the "Manage Attachments" button, navigate to where you have the image saved...
SgtWookie
Joined Jul 17, 2007
22,230
It sure did post. Good job!
What are the ratings for the LEDs that you are using? (Typical Vf @ current specification)
Is it LED2 that is looking dim?
What values are you using for R1 and R2?
ShockBoy
Joined Oct 27, 2009
186
Thanks, R1 and R2 are 1/4w 10K and the LED's are straight out of an old pc case. I had 100K resistors in but the flash rate was really slow.
SgtWookie
Joined Jul 17, 2007
22,230
OK, the 470 Ohm resistors you're using for the LED current limiting resistors are too low in value for the TLC555 timer's source output.
The basic formula for LED current limiting resistors (Rlimit) is:
Rlimit >= (Vcc - Vf_LED) / Desired_Current
where Vf_LED is the forward voltage of the LED at the desired current.
Right now, we don't have a clue what your LEDs are rated for, but probably somewhere around 25mA or less. However, you're limited by the 10mA that the TLC555 is capable of sourcing when Vcc is 15V. If your Vcc is less, it won't be able to source that much current.
What voltage are you using for Vcc?
ShockBoy
Joined Oct 27, 2009
186
12v starter battery from my boat. I've got it hooked into a L7812 vr circuit on a breadboard. I can easally put 3, possibly 4 led's into this and have them still light up.
Led 1 is the one that stay on when led2 is inserted. If led 2 is removed, then led 1 blinks normally.
Thank You.
SgtWookie
Joined Jul 17, 2007
22,230
Well, if you're using a 12.7v boat battery, then the output from your 7812 regulator will be around 10.7v. At that voltage, your TLC555 will be lucky to be able to source around 8mA current.
I'm assuming you bought the TLC555 at a local Radio Shack store; they sell them.
They also sell the LM555 timer. The difference is that the TLC555 is CMOS, meant for low-power circuits and is much more efficient. The LM555 is a bjt (standard bipolar junction transistor) design; it can source/sink much more current than the TLC555 design.
You could opt to add an NPN transistor and a base resistor to drive D2, or go with an LM555 timer.
Here's how you could add the NPN transistor and a base resistor to drive D2:
Oh, I changed R1 to 2.2k to make the on/off times of the LEDs more even. You shouldn't go that low with the TLC555. Better to reduce C1 to 1uF, and increase R1 to 10k, R2 to 100k.
ShockBoy
Joined Oct 27, 2009
186
That clear's things up, Sgt.Wookie, I'll keep you updated. I will give your solution a shot. I'm new to this, There are 2n's all over the place (net) I've got salvaged parts and none of them are marked 2n...anything... I know npn and pnp but..I don't know.. I got the tlc from an old tape deck. never giving up... I love this bleep.
SgtWookie
Joined Jul 17, 2007
22,230
The 2SC1815 would work just fine in this application.
Either of the datasheet search sites I mentioned above should have a datasheet available.
ShockBoy
Joined Oct 27, 2009
186
I will try both ways. Can someone explain to me what happened in my schematic? Why did one LED stay lit when the other LED was inserted? Something to do with the discharge terminal and the low output?
SgtWookie
Joined Jul 17, 2007
22,230
Bill,
ShockBoy is using a TI TLC555 LinMOS timer. When Vcc=15v, it can sink up to 100mA, but source only 10mA. With his Vcc=10.7v (12.7v battery with a 7812 regulator dropping 2v), I estimate that it can only source between 5mA-7mA; not very much.
ShockBoy,
You might try swapping the LEDs around. I have an idea that one of them may be shorted.
When only L1 is in the circuit, it flashes. When L2 is added, L1 glows steady.
So, remove both L1 and L2, and try using the LED you're using for L2 in L1's position. If it doesn't flash, the LED is shorted.
C PCB Layout , EDA & Simulations 15
L Digital Design 20
