Tl494+IR2110
Rcblack1979
Joined Jan 2, 2020
Hello everyone in the AAC community. I recently built this motor controller based on TI's TL494 and IR2110 mosfet driver. Although it works great i have a question. I have the ir2110 configured as a dual low side driver and both motors work, if i where to place both motor on the same shaft to spin it will the output power of the motors add up, or will the output power alternate between the two motors?
Dodgydave
Joined Jun 22, 2012
11,395
Yes you can put two motors on the same shaft, you will get no sync problems and better power transfer, but if one motor is under powered it will act as a brake or extra friction.
ronsimpson
Joined Oct 7, 2019
4,788
I am not certain how you will connect everything.
The 494 has two outputs. Each is limited to 45 to 49% on time. By paralleling the two MOSFETs you can get to 90 to 98% on time max. It looks like you will have one output per motor. That will limit you to about 1/2 voltage on the motors.
I think you will have no problem with two identical motors on the same shaft. Even if one wants to run slightly faster, it will pull slightly more current but will be fine.
