tkinter optionsmenu saving the values
zazas321
Joined Nov 29, 2015
848
Hello. For my application, I have created an optionsmenu and I select some values there. The next time I open that menu, I want to be able to see the latest values that have been set:
Code:
    def settings_gui(self):
        self.innercanvas = tk.Canvas(canvas, width=500, height=500)
        self.options1 = tk.StringVar(self.innercanvas)
        self.options1.set("First") # WANT TO SHOW THE LAST UPDATED VALUE BUT IT DOES NOT EXIST AT THIS POINT
        self.options2 = tk.StringVar(self.innercanvas)
        self.options2.set("TWO") # default value
        self.options3 = tk.StringVar(self.innercanvas)
        self.options3.set("Three") # default valueC
        self.options4 = tk.StringVar(self.innercanvas)
        self.options4.set("fOUR") # default value
        self.options5 = tk.StringVar(self.innercanvas)
        self.options5.set("fIVE") # default value
        w1 = tk.OptionMenu(self.innercanvas, self.options1, "one", "two", "three")
        w2 = tk.OptionMenu(self.innercanvas, self.options2, "one", "two", "three")
        w3 = tk.OptionMenu(self.innercanvas, self.options3, "one", "two", "three")
        w4 = tk.OptionMenu(self.innercanvas, self.options4, "one", "two", "three")
        w5 = tk.OptionMenu(self.innercanvas, self.options5, "one", "two", "three")
        self.canvas_inner_window=canvas.create_window(50, 25, anchor='nw', window=self.innercanvas)
        confirm_button = tk.Button(self.innercanvas, text="Confirm",font='Helvetica 12 bold', width=20, height=2, command = self.ok)
        self.innercanvas.create_window(250,400,window = confirm_button)
        self.innercanvas.create_window(50,250,window = w1)
        self.innercanvas.create_window(150,250,window = w2)
        self.innercanvas.create_window(250,250,window = w3)
        self.innercanvas.create_window(350,250,window = w4)
        self.innercanvas.create_window(450,250,window = w5)
    def ok(self):
        print ("value is:" + self.options1.get())
        self.options1_new = self.options1
        print ("value is:" + self.options2.get())
        self.options2_new = self.options2
        print ("value is:" + self.options3.get())
        self.options3_new = self.options3
        print ("value is:" + self.options4.get())
        self.options4_new = self.options4
        print ("value is:" + self.options5.get())
        self.options5_new = self.options5
        self.innercanvas.delete("all")
        canvas.delete(self.canvas_inner_window)
I make a canvas within canvas when I click the "Settings" button. Within the settings, I wan to change some values and save them so the next time I open the settings I can see what is the current configuration:
https://ibb.co/X7Kcw5B
When I select the values, and confirm, I save them into a new variable self.options_new. Now the next time I open the settings I want to see that value instead of a default "One" "Two' and etc.
HOw can I do that?
jpanhalt
Joined Jan 18, 2008
11,088
You save them to a non-volatile memory, like EEPROM, and read from that or transfer those settings to another place, like user RAM.
zazas321
Joined Nov 29, 2015
848
Thanks for the reply.
My main concern is what do I pass to tkinter optionmenu function:
Code:
Because everytime i close and enter the settings menu, I initialize and create a new self.options1 variable. Instead of creating a new one, I just want to create it once, and after that do not create a new just use the one that was updated. So passing self.options1 is not correct here since its gonna be a fresh variable everytime.
