Tips for preserve electronics devices
Status
Not open for further replies.
micksmelanie
Joined Jun 27, 2020
36
In that case what would be a dry and cool place in my house to protect electronics? here where I live the temperatures vary from 30-37ºC I keep my electronics inside closed shoe boxes and inside the box I place the device inside a semi-open, slightly open anti-static bag
SamR
Joined Mar 19, 2019
5,539
Then there are conformal coatings, desiccants, or go whole hog and dry instrument nitrogen gas inert purge and hermetically seal to eliminate oxidation. Realistically, putting them in a plastic garbage bag, boxing and keeping in a closet does wonders. Much better than leaving them in an attic, garage, or shed.
SamR
Joined Mar 19, 2019
5,539
Nothing lasts forever. Organic materials, IE plastic, paper, and rubber, breakdown over time. Metals oxidize. Crystalline materials are fairly inert. Electrolytic capacitors dry out. Most museum pieces have had some or substantial renovation to make them presentable. Vacuum tubes lose vacuum. Like I said, wrap it in plastic, put in a box, and stick it a closet. Then, maybe, cross your fingers and hope for the best. Better yet, sell it and invest your windfall.
35,207
1) Remove the battery.
2) Remove any battery residues with isopropyl alcohol.
3) Clean and dry the unit.
4) Dry silica gel packets in the oven at 125°C for 4 hours.
5) Put the silica gel packet along with the item in a plastic bag and heat seal the bag.
35,207
Every time I receive a shipment of electronics or buy a pair of shoes etc. I save the packets of silica gel.
Now I always have silica gel packets handy.
I bought my food heat sealer from the second hand store for a fraction of the price of a new one.
I save strong clean plastic for reuse. I make my own plastic bags from plastic saved.
I am an incurable hoarder and pack-rat.
micksmelanie
Joined Jun 27, 2020
36
Are naturally ventilated places like the ventilated room day and afternoon more likely to develop moisture and condensation inside the boxes and bags that are stored in that room?
jpanhalt
Joined Jan 18, 2008
11,087
In a warm, humid environment, which is what you seem to be describing, my major concern would be the humidity. Thick, plastic bags (black preferred) do great for preventing dust. Welding gases, particularly argon, are pretty dry. If you can flush the bag and seal it very tightly, that might help. If you can evacuate the bag, then partially fill with argon or nitrogen, that will lower relative humidity. The advantage of sealing under vacuum is that you can easily see whether the seal is still good.
micksmelanie
Joined Jun 27, 2020
36
Is it possible to keep a smartphone device stored in the box for long term storage, preventing the non-removable battery with flat cable from becoming swollen and leaking?
Reloadron
Joined Jan 15, 2015
7,954
Sooner or later components like capacitors will begin to breakdown chemically. You can run but you can't hide from certain forms of deterioration. You can slow the process using certain storage techniques but eventually things deteriorate. I guess part of an answer depends on what we call long term storage? I figure 10 to 20 years is long term. Some people may see 1 to 5 years as long term?
Ron
Reloadron
Joined Jan 15, 2015
7,954
My brain has been is storage of 47 years. Is there anything I can do to revive it safely? ;)
When I retired we were making systems which would need refueled in 40 years. I remember thing I'll be long dead before these things ever see daylight again. :) If you have any luck with that let me know. :)
Ro
Status
