Tiny Mercury Switches
Ya’akov
Joined Jan 27, 2019
10,298
I just received these very diminutive mercury switches and thought they might be useful for some of you. I can't say I have ever seen them this small. The seller does not provide specifications so I don't know what the current handling capacity is, but since these are probably destined to pull a GPIO up or down that's not really a concern.
A four wire measurement says they are about 40mΩ closed and the Fluke 287 reads about 0.05nS open. They should find a use where normal microswitch limit switches won't work.
Approximate Dimensions
For size comparison, with a 5mm LED
[EDIT: fixed the conductance measurement which was off by an order of magnitude]
peterdeco
Joined Oct 8, 2019
484
We stopped using mercury switches years ago when the EU enacted ROHS. We use tilt switches in a similar size metal can with a metal ball inside. I must say the ball switches gave us some trouble at first due to largely increased switch bounce.
Ya’akov
Joined Jan 27, 2019
10,298
I have some of those switches and I don't like them very much for exactly the reason you mention, bounce. It can be dealt with but they seem a bit flaky in operation when the angle is marginal, or at least the ones I have do. Not as repeatable as I'd like.
MrSalts
Joined Apr 2, 2020
2,767
Make sure you are not violating any shipping laws if you mail these. There are very strict packaging laws for shipping elemental mercury and all other hazardous materials (a.k.a "Dangerous Goods"). There may be a minimum quantity exception but, is better to check first. Also, if you ordered it from a foreign supplier, you are the responsible party in case there is a spill, contamination, poisoning or unsafe packaging inside the US.
MrSalts
Joined Apr 2, 2020
2,767
You know, sometimes I wonder how much smarter I would be if I hadn’t played with lead and mercury when I was a kid. It’s scary!
Bob
Maybe you played with just enough. Like salt, just enough makes food interesting - too much cause osmotic issues. .
KeithWalker
Joined Jul 10, 2017
3,618
I used to salvage the mercury by the pound from failed Ignitron tubes as a source of beer money.
It never affected mu..me..me me........
I had a tobacco tin full from a broken U-tube barometer. I played with it and it ate my aluminium Batman ring but it didn't affect me eithth,,,thth...er!
Reloadron
Joined Jan 15, 2015
7,948
When my company was paying to have hazardous materials removed I saved them some money.
Precision mercury in glass thermometer standards.
I also grabbed the mercury bulb pneumatic thermostats. :)
Never saw mercury switches that tiny. Pretty neat.
Ron
KeithWalker
Joined Jul 10, 2017
3,618
I have some of those mercury switches too. They make really repeatable tilt switches with a very small hysteresis angle..
k1ng 1337
Joined Sep 11, 2020
1,038
For you older members: Should I avoid playing around with mercury and lead? I got myself some PTH boards and am thinking I should learn to use lead free solder while I'm ahead brain cell wise. The opinion on the internet is small amounts are ok but what constitutes a small amount?
Reloadron
Joined Jan 15, 2015
7,948
As an older member I did play with mercury and melted and cast lead as a kid. I still handle lead on a regular basis and like using lead in solder you just take precautions. I handle lead bullets all the time, I also wash my hands with soap and water. You develop and apply good work habits. You don't tempt fate. :)
Ron
As kids we would remove the sealing lead from old tin roof barn nails to form small bullets, by biting the lead, for bicycle spoke guns (search for the term if curious).
Yes, don't tempt fate playing around with mercury and lead.
MrSalts
Joined Apr 2, 2020
2,767
The vapor pressure of lead is quite low. Unless you plan to lick each solder joint. You're not getting much lead exposure by soldering.
