Hi all
Background:
- I recently built the Sunfounder advised Timer555 circuit (I have attached the circuit diagram)
- I am inputting the output pulse from the Timer Circuit into my Raspberry Pi 2B
- The Timer and corresponding code works in terms of: 1. The timer outputs the pulses and the code reads them and I can manipulate the pulses into real time data.
- I have soldered (very amateur like) the circuit onto a breadboard. to bridge some of the connections i used short, straight pieces of solid core wires.
Problem:
1. The frequency of the pulses seems to change constantly by up to 0.05Hz. Now this is sufficient to induce a massive time change.
2. I try to calibrate the Timer555 circuit against several stopwatches and over an hour the time difference can vary up to 2 minutes.
Can anyone advise me how to eliminate changes in frequency? I have tried insulating the circuit with little success (perhaps temperature is the problem)(perhaps my insulating was not good enough)
Thank you
Misha
Background:
Problem:
Thank you
Misha
