it means, this stray voltage will be run out of after a few hours, and in fact no consumption of current drawn from the socket, right?What you are seeing is ghost voltage or stray voltage. It is caused by induction of voltage from the parallel runs inside the cables and was never a problem in the incandescent lighting days since it has almost no ability to drive a load.
But LEDs will light perceptibly with even a very small current so now it can be seen. A small load is enough to stop it (e.g. a nightlight bulb, or a 3K PTC properly rated for the mains voltage (if you don’t know what this means, don’t do it).
The stray currents are going to persist for as long as you have your mains power turned on. The current involved is very tiny, it would have no real impact on your usage in terms of billing.it means, this stray voltage will be run out of after a few hours, and in fact no consumption of current drawn from the socket, right?
Some Electricians tell me to reverse the wire order.The stray currents are going to persist for as long as you have your mains power turned on. The current involved is very tiny, it would have no real impact on your usage in terms of billing.
| T | 555 timer kit modification show-and-tell | General Electronics Chat | 11 | |
Appliance on-off timer with LM555 and CD4020B | Analog & Mixed-Signal Design | 18 | |
| R | bypass timer on circuit board? | IC Design | 5 | |
NE555 timer pin5 | Digital Design | 13 | |
555 timer in astable mode, first pulse longer | Digital Design | 12 |
