Timer Kawasan
linhvn
Joined Nov 6, 2024
297
I am using this timer Kawasan, setting 2300 the LED lights are turned off, but after turning off, there are some still LED burning vaguely, slightly? Is there some electricity leaking to the load?
Ya’akov
Joined Jan 27, 2019
10,308
What you are seeing is ghost voltage or stray voltage. It is caused by induction of voltage from the parallel runs inside the cables and was never a problem in the incandescent lighting days since it has almost no ability to drive a load.
But LEDs will light perceptibly with even a very small current so now it can be seen. A small load is enough to stop it (e.g. a nightlight bulb, or a 3K PTC properly rated for the mains voltage (if you don’t know what this means, don’t do it).
linhvn
Joined Nov 6, 2024
297
it means, this stray voltage will be run out of after a few hours, and in fact no consumption of current drawn from the socket, right?
Ya’akov
Joined Jan 27, 2019
10,308
The stray currents are going to persist for as long as you have your mains power turned on. The current involved is very tiny, it would have no real impact on your usage in terms of billing.
linhvn
Joined Nov 6, 2024
297
Some Electricians tell me to reverse the wire order.
