Timer Card ( Help )
icemanz
Joined May 8, 2015
5
Can anyone help me out with this problem? i wanna install a photo beam on site A
If a vehicle stop at site A i want my timer card to do ...something like
If Object block the photo beam it will activate the timer card and if the time timeout at 60sec it will trigger my siren if before 60 sec the odject unblock my photo beam the timer card will reset the 60second countdown .. any idea how to built this card?
12,128
What you want is called a retriggerable monostable with a 60 second period. As long as the input changes back to the normal stage before the 60 seconds times out, the output never changes. If the input is in the other state for more than 60 seconds, the output changes and activates something like a siren. Two questions:
1. Does the siren stay on even after the blockage is removed and has to be reset manually, or do you want the siren to end as soon as the blockage moves? In the latter case, the siren might be on only for 1 second.
2. Do the photo beam circuits and siren already exist, of are they part of this project? If they already exist, what signal does the photo beam produce and what signal does the siren require (voltage levels, currents, etc.)?
If, for example, the photo beam puts out a 5 V level when clear and 0 V when blocked, and the siren requires a low level to activate it, the timer circuit can be done with 1 capacitor, 2 transistors, and 4 resistors. Or a 555 circuit, or an LM393 comparator circuit.
icemanz
Joined May 8, 2015
5
oh i see..cool .. i want the time can be adjustable
1. after blockage the siren will deactivated and reset automatic ..
2. Its new projectand before i start i need this timer system first . the voltage for the photo beam is 10.8V -25V DC ( non polarity )
this is the photo beam spec
ModelPB-30SPB-60S
Protection range30m60m
Detection methodSimultaneous breaking of 2 beams
Infrared beamDouble modulation pulsed beams by LED
Response time50 ~ 700mS
Supply voltageDC 10.8 ~ 25VDC(Non-polarity)
CurrentMax. 57mA
LEDTx : Power(Green LED), Rx : Sensitivity good (Green LED),
When an alram is initiated (Red LED)
Alarm outputDry contact relay output(N.C/N.O),
Delay time: 2sec(±0.5sec) AC/DC 30V 1A
Tamper outputDry contact relay output form N.C(Rx only), Contact action:
Activated when cover is deteached, Contact capacity : 30V
(AC/DC) 1A or Less
Temperature-20℃ ~ 60℃
Beam AdjustmentHorizontal:190˚(±95˚), Vertical:20˚(±10˚)
Mounting siteIndoor/Outdoor
MaterialCover : PC resin, Base : ABS resin
Dimension63 x 163 x 75mm (WxHxD)
WeightRx : 330g, Tx : 315g
FunctionMonitor jack output, Frost proof cover
IP ratingIP 44
OptionPole attachment(2pcs/set, Pole size: : Φ38~44mm),
Transmitter tamper S/W, IP 54
12,128
Almost there...
Does the siren have a control input, or just + and - power inputs?
Do you have a make and model number for the siren?
It looks like everything can be powered by 12 VDC. Is there going to be a single system 12VDC power supply, or separate power supplies for the photo beam and the siren?
How is this going to be packaged and installed? Indoors, outdoors, etc.
12,128
