It would be nice to test the contacts of a time relay, just as a normal contactor,.without having to put voltage on the relay. Just like a contactor, where you can push on the front side to press the contacts to test them, do time relays exist where you can also press in front to test the contacts??Should be possible to add a small P.B. to a timer circuit if needed.
What is the reason for needing to test it?
Max.
It would be nice to test the contacts of a time relay, just as a normal contactor,.without having to put voltage on the relay. Just like a contactor, where you can push on the front side to press the contacts to test them, do time relays exist where you can also press in front to test the contacts??How long a delay?
What's the voltage and current?
Many thanks Max. But how do you test a normal sealed timer relay? Let's say a timer relay that switches a motor from star to delta. If the motor won't go into delta, how do you test the timer relay?? Or do you replace it, because it can't be tested becausePushing the contacts over manually on most timers can be difficult as they usually employ a standard sealed relay.
There are sealed plug in relays out there with a manual O.R./test button, but you most likely would have to custom build the timer in order to take advantage of this type.
I don't recall ever seeing a commercial one.
Max.
Hi Max. Sorry again, i just posted another thread with a schematic, with a timer relay in it. Please reply on the other thread. I want you to reply, i want to hear what you have to say. Many thanksDo you have the present schematic of the system setup? it should be easily possible to trouble shoot with a meter.
Max.
You're very good Max. Everyone i asked, don't recall ever seeing one. They simply don't exist . ThanksPushing the contacts over manually on most timers can be difficult as they usually employ a standard sealed relay.
Max.
The Omron MK series is popular for this feature. They can be fitted with a mechanical feature indicating if the relay is energized and also allow a manual push to test button. I have used them quite a bit because at a glance you know if the relay contacts are made. They also make versions with rather than just a push to test button have a latching type button so a used can actually mechanically latch the relay contacts. Pictured below are a few which use a push button. The orange framework works the contacts. Also the button colors are significant as they signify the coil voltage. Blue is a 24 VDC coil and the Orange is 120 VAC. Also not visible is when viewed from above you can see a flag letting you know if the relay is energized or not mechanically. Many also include an On LED. Pictured are 11 Pin 3PDT versions.
Thanks Max. Yes i'm doing a project with two partners and we are going to look if we still need it. If a normal time relay is bad you can easily replace it.They are the ones I indicated in #6 but you would need to design a timer around them.
I still don't know why you would need it!
It is a simple ON-delay timer.
Max.
At last, So this IS a new project?Thanks Max. Yes i'm doing a project with two partners and we are going to look if we still need it. If a normal time relay is bad you can easily replace it.
