What sort of a time relay? Just off the top we have Repeat, One-Shot, Delay on Break, Interval and Delay on Make so with two threads on the subject this would go much better if you could describe which type of time relay as well as the intended handles voltage and current? A data sheet for a model would be nice about now.Do you test a timer relay or do you just replace it?. If it can be tested, how do you test it.
It is a timer relay to switch a motor from star to delta.Power it and initiate the energise input .
What is the nature of the timer, part No?
Max.
Yes, and this is what happens when we run two threads on the same topic.I see this is a double post!
https://forum.allaboutcircuits.com/threads/time-relays-with-test-push-button-in-front.136984/
Max.
